Build table for Bosch router
17K views 11 replies 4 participants last post by  Michealjohn
I just purchased a Bosch 1617 variable speed router and want to build a router table for it. I don't want to do anything fancy or large. I would like it to be a benchtop table. I just work on small projects, so I don't need anything with too many bells and whistles. I was thinking of not using an insert plate and to install a t track for it. I don't do raised panels or anything that requires that large of a bit. I also don't have a dust collector, just a shop vac that I'd like to attach to it.
I was wondering what people would recommend or if they could show me some pictures of what they have so I can get some ideas on what to build.
Todd
HI Todd
If you can build a open end box you can make your own router table.
A router table is just a box on it's side that can hold the router for you upside down , no more no less,,,just pickup some plywood, make a box flip it on it's side cut out a pocket hole on it's side to drop the mounting plate into and you have it done..
If you want to use a fence just glue up some stock or use a 2" x 6"..
It is that simple .. no big deal... :)
IMHO, (in my humble opinion), and if I were in your shoes,
Hello Todd,
Welcome to the forums!
IMHO, (in my humble opinion), and if I were in your shoes, I would seriously consider:
Oak-Park's table kit
Unfortunately there's always shipping and in this case customs duties.
Still, if I had the room and wanted a bench-top style, I would have got this one. Instead I built an attachment to my table saw for mine.
As to a plate, it helps, it reduces the height you have to crank "up" your bit to do anything. Also it makes for easier bit changes and adjustments if you can "pop" it out of the table.
Cordially,
Gerry
#4 · (Edited)
Hi Todd,
yep it is, but it takes the guesswork out of it.
Cordially,
Gerry
PS:
Bob is correct in many respects, you could get away with a box and a hole for a router, quite inexpensively. You could make a fence out of a few 2x3's glued and screwed together and clamp it in place. You could also drop by Sears or your local "box store" and pick one up for the same price as the Oak Park one. The choices are nearly endless. The one important thing I would still recommend, and I'm pretty sure Bob would agree, is that you should buy a mounting plate for that puppy if you intend on making a box.
#8 · (Edited)
Hi Gerry
What guess work hahahahaha
Lets see 1/4 sheet of laminated plywood, one mounting plate and you have it done for less than 50.oo dollars..
Any kid in wood shop 101 can make a box :) the top and bottom don't need to fit the sides..that makes it a very easy job, in fact you want them to hang over the sides ...by 2" or more.. :)
how about one like below :)
#10 · (Edited)
Hi Gerry
Right on Gerry LOL,, It's called ping/pong :)
It gets the all the views points out in the open :)
