Do not, I repeat, do not buy a Porter cable router unless you want to through the bases away, both of them, and use the motor only in a lift, which is very expensive, wish I had known this earlier and bought a Bosch. All I hear about them is good, can't imagine you going wrong from what is said about them by users that talk about them on this forum. The bases on the PC routers may be O.K. for some folks, but it has been my experience that the parts that lock up the fixed base on the one I have are made of soft aluminum and wallow out pretty quick and the parts that I needed to replace the worn out ones were on back order an I never could get them. Actually I quit trying after buying the Mast R lift from Incra which cost considerably more than the router. I'm referring to the PC 893PK. I use the baes now to hold down scrap paper from blowing away when the fan is blowing in the shop, they work pretty good for that and if I misplace one of them, so what, they are absolutly useless to me in my opinion. I guess that it is fair to say that I can't say enough bad about the curret line of Porter Csble routers.
Jerry
