Craftsman Recreator.
18K views 16 replies 4 participants last post by  bobj3
Hi. I just purchased a Craftsman Router Recreator off of craigslist for $50. Not a bad deal. I was lucky enough to get the manual with it too. I just have a couple of questions maybe someone could help me out with.
1: The machine has been sitting for some time and the main shaft has rusted...nothing terrible, but enough to where the yoke will not slide freely on it. What's the best way to remove this rust and polish the shaft?
2: As far as I can tell, I have all of the parts, with the exception of stylus'. What can I use to replace the stylus? It appears from the manual that the stylus should be the same diameter as the bit one is using(which seems obvious) so what are some options in my case, since I doubt that I can get ahold of original equipment in this case?
I bought this machine to duplicate the corners of door and window casing in my home. Rather than the classic rosettes, I have curved corners that mimic the fluting in the casing. Essentially the fluting in the corner is a 90 degree radius which "connects" the vertical and horizontal pieces of casing.
Thank you in advance for your help!
Eric
#2 · (Edited)
HI EEEO
When I got mind it was about the same, with some rust on the main rod, you can clean it on the machine :),, get some 000 steel wool and with some 3 and 1 oil clean it up,the broz.bushing must be re-lube use the 3 and 1 oil aging,, it must move free from one side to the other ( free ) if you find that the steel wool is not doing the job get some 2000 sand paper and then clean it up, it must shine after you have it done....
" stylus " pickup some welding rod something like 1/4" 7018/7024 rod, clean the flux off with a brass hammer , shine it up and then on one end turn it down to 1/8" about 1" long and the other end is 1/4" , if I recall it's about 6.5" long..
I also has a lock ring that's about 1/2" OD diam. with a set screw in it, you can use a lock ring for a drill bits it work just fine.
Get it from ACE hardware for about 60 cents.
by the way keep the 3 & 1 oil right by tool, the saw dust will need to be removed from time to time and a new coat of 3 & 1 put on it, DON"T use WD40...
Thanks for the quick reply! I'll try the steel wool and sand paper if need be. I'm hoping it's not too far gone. I was hoping to avoid any mechanical(power tool such as a grinder) means of cleaning it up for fear of removing too much material and having slop in operation.
The welding rod is a great idea, I happen to already have some. I probably have some lock rings laying around too. I wasn't sure if the stylus that came with it was of metal construction or something else.
I'm pretty excited about trying this thing out. More projects for it have been coming to mind such as newal post caps for my stairwell, where two are missing.
#4 · (Edited)
HI EEEO
You're Welcome
Don't use any power tools on it, it must be true, if it's to far gone stop by a ACE Hardware/HD/Lowes and pickup a new steel rod and just replace it.
Be-sure to take your mike/caliper with you so you can check the rod some are not true size...marked as 5/8" but it's .610....you don't need any tent stakes I'm sure.. :)
" stylus "( holder asm.) mind was missing also so I made one b/4 I found the right one on ebay, if you want a snapshot of the one I made just ask and I will post a picture of it... :)
#5 · (Edited)
Hi Eric
Here's a snapshot of the stylus I made b/4 I found the right one :)
Made with hardwood and a 1/4" dowel pin in the end.
#7 · (Edited)
Hi Eric
The welding rod will do the trick :)
What I was saying make one like the picture, sometimes you need the extra room on the left side and the wood one will give that to you, it can move along the rod and then use the set screw to lock it in place, the one that comes with the machine can't move in and out to much...
Lets say you stick the pattern down on the left side and it's not in the right place so you will need to lift it and reset it but with the wood one you would just move it over and lock it in place...holding the pattern down is a big part of it..
I use the 3M double sided carpet tape most of the time..to hold the patterns and the blanks...
I think so, wood is more for giving than welded steel can be...sometimes :) and almost as strong , do you recall the OLD cars, Oak frames inside the body...
If you have some Alum. stock around that would work well also..cuts like wood almost.
Being a newbie
I will need to post at least 8 more messages to be able to use IM's. I'll try to be creative enough that a bot won't hijack the address.
rmagliac --- If you take the leading word or letters for each line
at --- then you will have my email address.
knology --- I haven't tried passing this along this way before
dot --- so I don't know how well it will work.
net --- Maybe good, maybe not. Thanks so much for the offer.
If the mail gets rejected, I'll get back with you and send a thumb drive, That always works. Thanks again
#11 · (Edited)
Hi Ron
Got it,,,, the email will be in 19 parts, because the file is 17mb
Just make a folder on the desktop and put ALL the parts into that folder
then run the RECR.bat file it will make the PDF file, then just click on it to open..
Now you can go back and edit your post and pull out your email address..
It will take me a bit of time to send it to you.
You're Welcome Ron
I wonder if you got it :) sometimes files just don't go right ..
Thanks for the feed back :)
