Craftsman Router Sub Base
5.2K views 4 replies 4 participants last post by  xplorx4
To all,
I have a Craftsman Professional Router 2hp 9amp 25K rpm Single Speed 1/2' collet Model: 315.27500. I have lost the sub base to this router that I have had for numerous years. I contacted Craftsman Service and the don't have a clue and state this part is not available. Does anyone know where I could obtain this sub base? The actual Craftsman part number is 973668-002 if that is helpful. Maybe someone has a replacement base (hopefully clear)?
Thanks,
Charboy
Hi charlie,
Welcome to the forum and glad to have you join us.
Two choices that come to mind for your sub base. #1 is to purchase a clear sub base (about everyone carries them) and drill the holes yourself or use a kit to help you center and locate the hole placements. #2 would be to look at the Milescraft sub base (try Amazon.com) which is pre drilled for a ton of different router models.
If you need more help, post again and we can provide some links to specific products.
Charlie greetings and welcome to the forum.
