Hello. I bought my router some time ago but didn't use it much because my unsteady hand coould not hold the damned thing straight, however the cuts were getting straighter with practice but recently i picked up a router table that was designed to go with my router and finally got round to mounting it today. A project i want to build is some shelves and although you can buy metal angle brackets as cheap as chips, I saw a design for some home made wooden ones whcih although would cost more to make than buying some metal ones, the sense of achievement would be greater. The angle brackets use a dovetail joint and i have a dovetail bit for my router but my question is that although it's obvious how to cut a dovetail groove, how would one cut the bit that slides in it? is there a tried ant tested way or is the way i'm suspecting that uses quite a bit of measuring the only way?
