What do you use to clean saw dust off your feet so it doesn't track through the house? Drug house gets so full of sawdust so quickly after a few times through I need to clean off the rug.
My shop (garage) is attached so it's strait from the sawdust into the house. I wear work boots, so not the easiest to remove each time. Also I have a 5 & 6 year old boys, so I'm fighting a loosing battle but who knows maybe someone out there has a brilliant idea.I take mine off on the front porch before I go inside.
On one hand, thankfully there is no OCD/drama issues related here. Regardless, I know the sawdust makes a mess and I have young boys who want to come out and help daddy work. Half the time they come out in sock feet (which REALLY picks up the sawdust). So far the best option I've seen suggested is the brush caddy. That seems most likely to wipe off the wood without clogging like a rug does. Maybe use that as a first step, then the rug/door mat as a final wipe before coming inside.if it's still an issue, no matter what you do it may be an OCD/drama issue and those a tough ones to work with/round...
vent the hose or the head for less suction...It is thin so the Shop Vac sucks it up and won't let go.
