Fitting Of Fence On Triton 2000 Workcentre
14K views 24 replies 8 participants last post by  old55
Hello there,
Hope I'm in the right place to ask this question. Started to assemble my Triton 2000 Workcentre today. When I got to fitting the fence, on one side I had to slacken off the nuts on the springs at one end. So the arm would slide in,the other arm went in fine. I can lock the fence in position. I'm not sure if I have fitted the fence as well as could be done. Any help would be very welcome.
Cheers,
Peter.
Can't help you, Peter.
I only had the Mk3 work centre and had no problem with the fence.
You do not say where you live..
Check out this forum...
Woodwork Forums
They have a special area just for Triton gear.
Peter, I'm not sure which springs you refer to. I've had this table since, would you believe, 2000! and I don't recall any adjustments required when sliding in the fence. It's worth taking time to accurately set up the saw, preferably the Triton because that has holes in the base that fit over cams which makes the set-up fast and accuracy is easy to obtain. The rise and fall table is, in my opinion a necessity. Here are some shots of mine which might help.
setting fence
Harry,
I see that Carba-Tec has them back on the market.
How difficult is it to make sure the fence is parallel to the blade?
Using the Triton saw James it's a piece of cake, set the fence so that it reads zero in-feed and out-feed and adjust the cams so that the blade just touches the fence front and back. If on a test cut the wood tightens or loosens during the cut, slight further adjustment is needed but from memory, the initial set-up was accurate and I haven't touched the setting in all these years and if I set both ends of the fence to 200mm, then the piece of wood is exactly 200mm. For a pressed steel table, the results are remarkable. Often at wood shows when I see magnificent looking table saws I become tempted, then I remember what a perfect job the Triton does and the temptation vanishes.
I do recall that when I bought the work-centre I fitted my AEG saw which took over half a day and I still wasn't happy with it so went out and bought the Triton together with the rise and fall accessory (the latter causing me great difficulty to understand the instructions until my granddaughter who would have been about 12 at the time said something like " granddad, do you think it means................"and it did!)
Thanks Harry,
May give one a serious look at this weekends wood show.
I was very happy with the MK3.
The GMC table saw is a bit small for ripping plywood sheets.
hi there,
I have used the triton 2000 for about 10 years and never had a problem , still as accurate as the day I bought it, it just has a few scars.
The only suggestion I have is to give an extra millimetre width on the outfeed side of your work, this helps stop any chance of binding with the riving blade which can happen, you will still get the accuracy fom the cut.
Enjoy
Hankus
Hi Peter,
Have you been able to solve your problem???
It is nice to get feedback to show we are on the right track...
#16 ·
height adjuster is great, well worth the cost,
also I have closed the frame in - I simply placed a piece of custom board on each side and one across the bottom.
then placed a connection for my dust extractor in the bottom, very simple works well and the price was right-
I only use this for a table saw and also fit a router table top in it.
#20 ·
Carba-tec did not have any on display at the Working With Wood show this last weekend.
They only had a Triton Router (the new model TRA001 AU) and a router table.
So I did not get a chance to road test one....
#23 ·
You can see the difference here. The original cast plates were quite skeletal.
The newer pressed steel ones have a notch cut out on one side that is necessary for part of the rise and fall kit to pass through and there is no easy way no adapt the older style plates or I would have done.
#25 ·
Welcome to the forum Deon.
#1 - If you mean lock the trigger on you can use Velcro or a like product
#2 - Not sure what you are asking
I'm sure someone will be able to assist.
