Grizzly GO462 vs, Delta 46 460
6K views 3 replies 4 participants last post by  mgmine
I think that I have narrowed my choice in my first lathe down to either the Delta 46 460 or the Grizzly GO462. The Delta machine is an extremely good tool and is the one that my brother has and likes. The Grizzly has a larger swing than the Delta and a nice heavy cast iron set of legs and/or base. So far all that I see wrong with the Grizzly from what I am reading is that it runs a bit to fast for the larger bowls but with some careful cutting with the BS most of the problem with running to fast for starting a new workpiece might be minimized. I am interested in the ability to make the larger bowls and of course the heavy and large base is appeals to me too. Right now I'm leaning toward the Grizzly but am taking my time to make my decision and enjoying the reseach which includes the posts to my questions on this forum. Comments please.
Jerry
#2 · (Edited)
Only you know what you want to do on a lathe. The Delta 46-460 is what is known as a midi(read small) lathe. Comparing it to a full size lathe is like comparing apples and oranges. For small turnings like pens, tops, small bowls, etc it will be ok. If I was going to go that way though, I think I would look at the Jet midi.
If you plan to do larger turnings, the weight is not sufficient. You will have to bolt the lathe down to something very solid and heavy! Even then the bearings and such probably are not up to the task!
If your goal is to do larger bowls primarily, the size and weight of the Grizzly will be to your advantage. My thinking is if you want to turn anything too large for the Grizzly, you definitely will not want to do it on the Delta, either. You will want something much more expensive and substantial. Th spec I saw rate the motor on the Delta at 1 HP Max.. that tells me it is most likely a true 1/2HP motor.
I think you would be happy with either as long as you use them within their limitations.
Here is a rather extreme lathe made specifically for large bowl turning just to put things in perspective. It is $8000.00 by the way!
I know Bernie W recommend the big Jet lathe, But I would not put 2000-2500 dollars in a lathe not knowing if I even like turning. The Grizzly or even the Delta should be a nice learning tool. If(and when) you outgrow it, you will know much more about what you need and want at that point. Turning 20" bowls is not the best starting point to learn lathe techniques.
I have the Delta lathe. It was initially recommend to me, I did a lot of research on it and the Jet. The Delta, in my opinion edged out the Jet with easier belt changes, a wider belt, and the ability to run in reverse made it the better of the two choices. With the extra bed extension you can do longer turnings, such as table legs. For someone starting out, it is a lathe that will grow as your skill will grow.
The reality of turning is that over time, the cost isn't the lathe itself. It is all the accessories, tools, and other equipment that goes along with it. That said, unless you buy a large 24" lathe today, the one you buy now is very likely not going to be your last lathe you own.
A note for the speed, just because you have it well cut out the bandsaw, you still want to start a bowl blank at the lowest speed possible, slowly rev the speed up till the lathe starts to vibrate, the back it down a bit. While you can get pretty close on the bandsaw, the work piece will still be out of balance, and you may find 600 RPMs, even on the heavier machine, is too much.
