Help Finding a Stroke Sander
5.9K views 16 replies 14 participants last post by  kp91
Hello fellow members. I make live edge cheese boards, by buying from our local sawmills cross cut pieces in walnut, cherry, and maple. I use a double drum sander for my first sanding after I air dry my pieces. I find that I have to use too many passes to do much sanding of my raw pieces. A person who works with wood has recommended a stroke sander to me. Does anyone have experience with stroke sanders and, if I purchase one, which type would you recommend? I am really looking for the best way to do my first sanding of cross cut wood. I appreciate any help members can be to me.
Stroke sanders are a whole different animal from oscillating spindle sanders. I researched the later and found the best value is the Shop Fox which has a 1/2 hp motor. Most others use 1/3 hp motors.
You can easily find a commercial model used for about 100$. They are not much in demand anymore. The problem is dust collection and space requirement, you could cut one down to 3' or so for your application. some times the 2 ends are separate pedestals and you set them apart by the length you need and order belts accordingly. I saw one like that sell for 10$ a few years ago.
Rob
Hi Bill
I've seen them go pretty reasonably also but not for several years. I would try running the thru my 20 inch planer lengthwise even if I needed to use a carrier board on the first side.
If they are wider than 20 inches you would have to find a wider planer. Some saw mills also have planers up to 36 inches or so.
Regards- Dennis
A stroke sander is a tool you will love. It is sometimes called a panel sander. Mine is a Boice Crane that I picked up at a high school woodshop auction for $150. It went cheap because it is 3-phase, but I have 3-phase power in my shop, so I got a deal. Belts are available on eBay or you can glue up your own. Mine handles 5 foot width. My brother made his over 40 years ago and it will do 7 foot plus doors.
#16 ·
You can always make one, plenty do. Here's one example.
Quittintime: Homemade stroke sander
Do a search, using 'homemade stroke sander, as your search phrase, and you'll come up with all sorts of info.
