Hinge cutter
8.4K views 11 replies 5 participants last post by  Cherryville Chuck
Hi everyone
Can anyone help? I am looking for a 35mm cutter, for fitting ressed hinges on wardrobe doors, that I can use in my router, 1/2 or 1/4 inch shank. I have one for a drill, but would like to set up a router to do the job if possable? I am in the U.K, but don`t mind paying shipping for a good tool.
Regards
Paul
Hi Paul - Bits that size should be available on your side of the pond but I think for using a router to do that, I would prefer using a template:
Rockler Concealed Hinge Router JIG IT® - Rockler Woodworking Tools
That one uses a 5/8" bushing and a 1/2" bit but I would guess that Trend would have something similar and metric friendly in the UK. :)
If you can find a 1 3/8" or 35mm straight bit it should work. I looked at CMT for one and didn't see either. However Southeast Tool sells 1 3/8. Maybe Freud, or as John suggested, Trend may have one. You would still need a way to hold the router in place, so John's suggestion might be more practical and you can use an easy to find bit to do it with. To me, the simplest way is still the drill press.
Hi Paul - I did a little searching around this afternoon. This one seems to be what you are looking for:
Woodworker.com: WOODTEK STRAIGHT PLUNGE CUTTING ROUTER BIT
Item #818-935.
I'm not sure it is a true plunge cutter, artwork looks like it may be. There are a lot of 1-3/8" Mortise bits about but they are not true plunge cutters as the centers are relieved, depending on movement to clear the mortise.
There is still the issue Chuck pointed out about aligning the router but, if you have a lot to do, a fixture could be put together to take care of that. :)
#5 · (Edited)
I am looking for a 35mm cutter, for fitting ressed hinges on wardrobe doors, that I can use in my router, 1/2 or 1/4 inch shank. I have one for a drill, but would like to set up a router to do the job if possable? I am in the U.K, but don`t mind paying shipping for a good tool.l
Hi Paul
Contact Wealden Tool and ask for a T1835A. I have one and carry it in my kit all the time. Designed for use in the router (as opposed to drill press types), accurate and cuts very cleanly, but you do need a 1/2in router for this and the speed needs to be turned down. They do an 8mm shank version, too, but I think such a large cutter is better on a thicker shank
BTW Wealden will deliver most orders next day if you ring before about 3pm (3:30 at a pinch)
Hi Chuck
You know, we do metric here (UK), too! The Trend cutter is in the Professional range and is heavier than the Wealden, but costs more...... I agree that a drill press is easy, but for site work I can't carry one. Instead I use the router fence to set my centre offset from the edge (in Europe routers all seem to come as standard with a side fence) and draw a couple of pencil lines part way across the back of the door with a square so I can line-up the cutter "dimple" using the centre line marks on the base of the router (my DWs and Elus pretty much all have these). Initial set-up is done on a scrap of timber to be on the safe side. Must have done at least a couple of hundred hinges this way over the last 6 or 7 years
Regards
Phil
Hi Phil,
I received an edge guide wit each of my routers though I can't remember the last time I used one. I hadn't thought of using them to set up for offsets. I gather you haven't had problems with the bit wandering?
By the way, I can tell you how to make a simple jig for drilling with hand drill and forstner if you want to go back to that method.
Hi Chuck
Not really. If push comes to shove I can always resort to clamping the router in place! This has been necessary a few times in the past on kitchen doors with slippy melamine back faces, although I tend to add a strip of double sided tape as a temporary measure these days if I need it
:laugh: I do carry round a small selection of Forstners for installing door furniture, but I prefer to use the router method on kitchen/bedroom doors because the depth stop turret on the router gives me a very accurate way to control the depth of cut. Nothing more nail biting than drilling 12 or 13mm into a $100 door which is only 16mm thick without absolute depth control
Regards
Phil
The cup bit I have is carbide as well. Cuts like butter but was about $35 Cad. You get what you pay for as the saying goes. It has spurs and I think the center point is longer but I don't have it to look at right now.
I agree, the shipping must be the issue. The difference in price between 15 or 16mm and 18 or 19 mm isn't that much. It sounds like the engineering hasn't quite caught up to the desire to reduce costs.
