Hi Danielle, welcome to the forums
Remember that the bits are specified in RADIUS. This says that a 1/2" circle has a 1/4" radius. If you use a 1/2" radius roundover on 1/2" stock the profile would be a sharp edge at the bottom rounding up to the top surface. A 1/4" inch radius bit would yield a straight edge for the first 1/4 inch and a rounded edge leading into the top surface. If you ran the 1/4 inch along the top surface, flipped the work over and ran it again, you would end up with a rounded edge. I hope I'm not to confusing with top/bottom. It inverts on me using a table vs hand held.
If I just want to ease the edge of a piece of stock I will generally use a 1/8 inch roundover, and go to higher and higher numerical radii bits the more pronounced I want the arc.
I better quit before I confuse myself..
