How to Cut Small Circles?
19K views 22 replies 9 participants last post by  harrysin
Hey Guys, I'm hoping you all can help me out with this...
I am wanting to cut some small circles that are about 3.75-4 inches in diameter. I have a full size Craftsmen router and the base is bigger than this size so it wont work with the Jasper circle jig. I also have a Dremel tool that has an attachment to go down to this size but the bits will tear up fast and wont do so well with 5/8-3/4 thick MDF.
Are there any other alternative ways out there?
#2 · (Edited)
Hi Kevin
The Jasper you have will do the job just fine you just need to rework the Jssper just a little bit, that's to say drill out the 1/4" hole to a 3/4" or 1" hole in the Jasper and use a brass guide in your router base..no need to bolt the Jasper to your router base..
Lee Valley sells Forstner bits of the size of the circles you want.
#7 · (Edited)
Hi Kevin:
Ok, you've got a bunch of options here. Firstly, the trammel method is a bit difficult to handle on small sizes. This is the normal centering jigs that you see. If you chose to go this route, make sure you can walk entirely around your table and keep your hands on the router while cutting the hole. You might pull it off with practice, care and patience.
However, your ideal is Santé's circle cutting jig.
http://www.lescopeaux.asso.fr/Techniques/clic.php3?url=Docs/Sante_Tripode_Anglais.pdf
Also, equally successful is the pivot frame.
Hi Kevin,
The Jasper 400 circle jig will cut holes from 1" to 7" in 1/16"increments.
(this is the round jig, not the oblong jig((200?)))
I have cut 4" holes with a Makita 3612C router with no problems.
I believe it should handle your Craftsman.
Harry,
I made your jig to suit my Ryobi router, but did not secure the rods properly.
I am going to modify to take 1/2" threaded rod for the makita.
I have not set the formica yet. What glue did you use?
#16 ·
Hi Kevin,
Sorry for hijacking you thread, but you can see there are a number of ways to solve your problem. All of them should work with your craftsman router.
have you found the answer you were after?
harry, I will post pictures this week end as I cannot access the shed during the week. (dark when I get home from work).....
Thanks also Al.
#22 ·
AL,
You do not need the fence if you use a hardwood block as Harry did.
I used a wooden block and I need to secure the rods in a better manner. I will take a clue from Harry and file a groove and glue in.
