I've made a start
3K views 19 replies 12 participants last post by  BernieW
With glenmore "turning" out pens in wholesale quantities lately and the fact that Deb now has a lathe and will no doubt commence making pens in the very near future, I decided to make sure that after a long delay I could still make pens. I used the metal lathe for these acrylics which takes longer then a wood lathe but for slimline acrylics is very accurate. This photo shoot is more a collection of shots rather than a tutorial.
It is indeed an ML7 Neil, a pity that it isn't a Super 7. This one was made in 1947 according to it's serial number. The same model was still available in recent years. Here in Australia spare parts can still be had from MiniTech in Queensland.
It's good to see you back on the forum, I hear from a usually reliable source that you have been busy making items for a good cause. Newer members won't be familiar with your work Neil so how about some photographs.
"This photo shoot is more a collection of shots rather than a tutorial."
I can't believe you said that....ROTFL.....
#12 · (Edited)
The acrylic blanks were a present from a forum friend in America, the material was very easy to turn.
NO, on a wood lathe no chuck is required, the two halves of the blanks are drilled first, tubes glued in and then go onto the mandrel, having said this, the Super Nova chuck that I bought, I wouldn't be without, I use it for just about everything other than pens. As a matter of interest, what thread does your lathe have? Adaptors are readily available, so if I ever go to a bigger better lathe I shall still be able to keep my chuck.
Nice photo shoot Harry...better than some tutorials I've seen, LOL. That's a great set of pens and you have a very good process for making them, not the least to say equipment too! One thing I have learned recently that I would like to pass on: As you mentioned there is not much acrylic left when you are done and sometimes you can see through to the brass tube or maybe the coloring is off a bit as a result. You can paint the inside of the acrylic, just after you drill but before you glue in the tubes. I use plastic paint that's used for models and apply it with a q-tip. The color doesn't matter, you can get creative. You can try to match the color of the acrylic or go with something else. White tends to lighten the colors, black will darken. It makes a difference in the look of the pen. Anyway, just wanted to pass that on in case you'd like to try it. It lengthens the time to make one since you have to wait for the paint to dry, but I think it improves the result.
Yes Frank, on occasions I have noticed a hint of the Brass tube but unfortunately I'm too impatient to go to the trouble of painting the hole first, but never-the-less I do think the idea has merit.
