For those of you that may have been following my posts on my new Grizzly jointer, you will recall that when I first set it up and tried it for the first time, I was pretty happy with my results, but recently when working on an actual project, things weren't looking as,well as they should. I will tell you that I was extremely reluctant to get into the re-set up issue. The manual said to double check everything with a straight edge before attempting to make any adjustments. The manual shows everything that needs to be checked and when I made those checks, things looked to be good. Sooo.... I began to mess with the ajustments that the operator is supposed to make or can make. Now, I have to make a confession. Before I did anything and when at first I thought that things were going pretty good, I had noticed that the workpiece was just barely bumping the end of the outfeed table and I had been just pushing past this slight bump, should have know that something wasn't right. Anyway after messing with the adjustments that the operator should make after the jointer is set up properly I was able to get rid the bumping on the infeed table. Also, with a longer workpiece, in this case, 24", I was getting some snipe at the end of the cut, ummmm. Well, after raising the outfeed table just enough to get rid of the bumping, makes common sense now, but had been led to believe from the manual that the outfeed table should be left alone, but that, I discovered, is not so. Then when the outfeed table was raised I went to the infeed table. What I learned is that the stops on the back side of the maching can be loosened which allows the tables to be lowered or raised more than was possible before before releaseing these stops. Once I had this extra latitude, I was able to get the adjustments made that were needed to obtain the results that I wanted. All of this with just one exception that I have not figured out yet, and it
is that I'm still getting just a slight snipe at the end of the cut. The infeed table is set for very light cuts, about a sixty fourth of an inch. When I make an edge pass for edge jointing, I have to press very hard on the end of the workpiece at the far end of outfeed to prevent any snipe, but I can prvent the snipe if I am careful.
So, all of this just in case anybody gets a new jointer and and has similar experience as I have with mine. When things are working right, the Grizzly GO604ZX is a great machine but if the operator doesn't do their part, you sure can't blame the machine can you.
After I posted this I phoned Tech Support and was informed that the snipe that I mentioned above is just normal for a jointer so I guess that all is as it should be with the settings. I think that a little practice may allow me to eliminate most of if not all of the snipe, and if not, I will just the workpieces a little long and cut the snipe off.
Jerry
Colorado City, TX
Jerry
Colorado City, TX
