Need to buy a drill press, any recommendations?.
4.9K views 38 replies 16 participants last post by  Artemix
Can't postpone any longer, need one asap for my project.
I've heard once a guy saying that some drill presses don't have a stop block incorporated, and I should stay away from those.
I'm sure there are more examples, and things I should look for and things I should avoid when choosing one over the other.
Any tips are appreciated!.
The adjustable depth stop on the quill is a handy addition Pablo. A decent quality DP should have that included. If you can get one that has parallel grooves on the table instead of the X pattern on most cheap ones I would go for that too.
I bought a beast . I think it's getting on the big side but I didn't want to do it twice. It's made by General and was around 1000 bucks . It has stops which are essential imo , but I would hope most do . Having a belt to change speeds is kinda nice to when you want to slow things down for certain materials .
Rick,
No wonder you can't get anything done in the winter! Do we have to have an insulation party?
Pablo,
All the advice is good...multi-speed and good quality, positive adjustments, solid construction and preferably a tilting table. Buy the best you can afford it is a lifetime purchase if you take care of it.
You have to determine your criteria. What do you expect that you will you be using the drill press to do. If you need lots of "stroke" go for a floor model, or if you don't plan on doing a lot of long/deep projects, a bench top model may do the trick for you.
Compare what is available and if possible look at them physically...use them if possible. Some stores may have demonstration units available to try. Make sure that YOU are comfortable with how it operates.
Make sure that you have good customer service from the manufactured and a reliable parts availability for whatever you get...parts wear... ("If it is mechanical, it will break"!)
Whatever you get, buy or make a table with a fence and the ability to clamp/secure your work.
Good luck
Bill
Pablo
A drill press is something you want to last a long time and do all you ask of it. It needs to be accurate and user friendly. Buy the best quality you can. At home I've had a 30 year old Buffalo. It does what I need. In our big shop we have a Grizzly model G9969. This is radial arm 500 plus pound animal.set up with the vices we use this mostly for milling 80-20 aluminum. For wood work we mostly use our Delta. Not knowing what is available to you,
Get the best you can that fits your needs now and into the future. Good equipment doesn't cost - it pays.
Dennis
#16 ·
Pablo,
all the info above is good. I also consider the quill travel important. Seems as though a lot of the new ones only travel 2 1/2" and I like more than that for woodworking. Also I use a quill lock quite often where I want to lock the quill at a certain place.
One thing you might look at is surplus industrial drill presses. They are built heavier duty and a lot of places are updating to modern digital controlled models and are selling off the old manual ones. I recently aquired a WWII Atlas that needed cleaning up and it is built like a tank. it also has a 4" quill travel and a quill lock.
Pablo,
Herb brings up some good points. Don't be afraid to look at used equipment in your area. Check with machine shops, mechanic shops, etc. they may be upgrading or know someone who is...just because they use the drill press for metal, doesn't stop you from using it on wood. Just ensure that it is not worn out.
I have picked up a lot of equipment that was used (most were slightly used). Yard sales are common here. I picked up a Delta 20" scroll saw for 20% of a new one (US$500.00+). The guy was moving to Panama and was getting rid of his equipment. He even threw in all of his wood clamps to seal the deal.
Check out swap meets, yard sales, flea markets or swap sites on the web for local items. You may find a deal on a DP that will be adequate to get the job done until you find the right keeper.
Bill
Pablo, in addition to what has been said by others, if you plan to use large bits on wood, like large forstner bits or hole saws, make sure the drill press has a slow speed. My drill press has 5 speeds with the lowest 500 RPM. That limits me. There are plenty of drill press speed charts on the internet. Here's one of them: https://www.fnal.gov/pub/takefive/pdfs/Drill_Press_Speed_Chart.pdf
#30 ·
Tell you the truth I was debating on buying one of Generals bench models too , as it's not like there a lot of money .
I just can't see drilling out teeny tiny holes in a circuit board with that beast I have :no:
