Poly Patina...who is she...?
7.7K views 38 replies 7 participants last post by  schnewj
I'm in the final stages of repairing a floor plagued by two common ailments..."wee doggee pee" and "...leak somewhere"
Boards have been cut out and replaced...glued and nailed...no squeaks. I even managed to keep most of the tongue and groove in the new boards...
Now it's time to stain/poly...(just a few more to go)
You might recognize the floor color..."Polly Patina"...years of light discoloring what used to be a nice natural look...
The floor was originally poly'ed only...and now it's got that orangey/yellowey look to it...
Oh, woe is me...now how to duplicate that patina...? Sanding the whole floor and redoing is not an option...although I've offered it...
Minwax products I've tried already...Golden Oak, Ipswitch, Natural
Other products...Amber Shellac
Mixes I've tried...Shellac/Golden, Shellac/Poly
Most of the attempts have yielded a brownish rather than orange'ish...Wish I could still find my favorite "Gym Seal"
I gotta imagine you guys have run into this before...
Thanks in advance...Nick
Reactions: RainMan 2.0
I agree with Chuck. You could match using something like Trans Tint, but the color will change with the age, and the patina of the new pieces as it changes. Those new pieces will eventually darken down no matter what you do to match them to the existing floor.
I would let them know up front that you will match the color as best you can, but that it will change in the future and you can't be held responsible. The only real solution, Nick, is to sand it all down and finish it the same.
Reactions: Nickp
You mean unfinished...? >:)
More info...customer finished it 4 years ago...used spar varnish only...no stain.
Got some in the garage so will do a test piece on Sunday...
Which one of you guys bought up all the gym seal in the world...? I know...that VOC thing actually killed it all.
Thanks for the sound advice...gonna take another shot at her on Sunday when I will show her all the cans of stuff I tried...
Well, if it was done four years ago, then just use the same spar varnish (which I personally wouldn't have used) and wait another four years for the new stuff to patina to match.
Rots of ruck Relroy!
Reactions: Nickp
#25 ·
THANK YOU, George ! ! !
I will definitely check this out...
#29 ·
Neely Dunn...
#31 ·
Except for another coat of poly, here is the result using George's Zar Amber stain...
#33 ·
Different ways ways to get the color
Good job. It blended well. You can be proud of a difficult job well done. I came across that stain when I repair a baptismal font and had to find the right color stain. I had to combine several different colors to find the right shade. In the past I have used artist oils to match stains. I was given the recipe at an adult education furniture refinishing class. A penetrating oil stain uses 1 part boiled linseed oil, 3parts turpentine pigmented oil colors (artist's oil paint). Another recipe is 1 cup paint thinner or turpentine, pigmented colors in oil to the density you wish, linseed oil -added to retard drying time necessary. If you are brushing on finish, add 1 or 2 tablespoons varnish or varithaine. This will make your stain dry hard and when you apply your finish, you won't pick up stain. Maple uses raw sienna, raw umber, and burnt umber. Walnut uses burnt umber, raw umber, and Van **** brown. Re mahogany uses burnt umber and Venetian red (use sparingly). Brown mahogany uses burnt umber and a touch on Venetian red (if necessary). Cherry uses raw sienna, Venetian red (sparingly), and burnt umber. Pecan uses raw sienna, raw umber, van **** brown, depending on what shade pecan you want. Start with raw sienna then add other colors as desired. Fruitwood uses raw sienna and burnt umber. Add burnt umber to darken stain. Fruitwood is darker than maple. I don't have the colors for oak, but with all the different oak stains out there it hasn't been a problem.. This recipe was given to me by Mel Wylie the class instructor 36 years ago.
#36 ·
George, out of curiosity, is there a set amount of the raw pigments (ratios) to add or is it just add, blend and adjust?
#35 ·
@prgl7
George, I had a feeling you had seen this "once or twice"...
Obviously you've mastered the art of finishing...hoping I'll be there one of these days but I'm sure I don't have 36 years left in me...
Besides the technical component of finishing in your post I think what I got out of it is to seek out a similar class as you described...it will help to see through that shroud of magic and wizardry we newbies typically see in finishing/matching.
In the meantime, can you recommend some good reading on the subject...?
Thank you once again...I'm sure this past project will not be the last you hear from me...
#38 ·
There is no ratio that I have or know of. When I seek to match a shade I will start with a color and then slowly add other colors to lighten or darken or to add different hues. It is for me an add, blend and adjust process. Someone out there probably could give you ratios, but remember we are trying to match a color that there isn't already a premixed stain. Also, most of my experience has been a learn by doing. I have found that wood working magazines often have finishing tips and that back issues can be obtained digitally. You can then search for answers using those back issues. I have used Wood magazine, Woodsmith, Shopnotes, Popular Woodworking, and Wood worker's Journal. There are many tips, hints, ideas, plans, jigs, pictures of what others have done. I have also found that Pinterest is a good resource for these things as well. Hope that answers your questions.
