Quick-grip clamps repair and improval
1 reading
17K views 10 replies 9 participants last post by  gav
Good day
I have those cheap grip clamps and after some use I noticed (as expected) 2 problems.
The plastic "handle hinge housing" breaking and
The jaw was sliding back and not "gripping"
For the first problem, I replaced the hinge with bolt and nut.
For the second problem, I grind the bar with #40.
The repair was so good that I made it on all the clamps, even the good ones.
Actually, I recommend to make it on the "good" ones because there is more "meat" for the bolt to hold.
Another improvement is...yep, the sanding paper, it grips like a Crocodile...
Niki, the clamps that I compared in my recent post were the one-handed spring type that you show in use in many of you're posts compared to the ratchet type . Regarding the bar clamps, I haven't had any problems with slippage or breakage, there must be different types available, mine have no country of manufacture so it's a good bet that it's China. Out of curiosity I just went out to my shed and opened-up a couple as I had never seen the innards before.
On a different subject, I must confess that I had thought of Poland as a rather poor country and was therefore surprised to read this morning that it has the fastest growing economy in the European Community. Cheers for now.
Good info. I have a couple of the Quick Grip clamps similar to Harry's 3rd photo but have not had any trouble with them slipping. They might be Irwin brand. Anyway, haven't had any of the real cheapies. I love my little cheapy spring clamps though with no ratcheting action on them. I use those a ton, quick and easy! Good idea with the sand paper on the pads!
Thank you
Harry
Your clamps are differently engineered and looks much better and robust than the cheap ones that I have.
Maybe Poland has the fastest growing economy but it come on the expense of the population.
The prices are going up every day (the building materials "jumped" to double price and so is the housing) but the salaries did not increase at all.
A good salary is around $700 and many Poles are going to work in Germany, UK, and Scandinavia where the salaries are much higher (even doctors).
After you retire you get $200~300...and you have to live with it.
Oh yes, the crime rate and corruption are going up slowly but surely...as expected
niki
I know that Niki is now deceased but I've been going through his old posts for ideas.
Anyway, I just thought I'd clarify that the amounts he posted are per month, and not per week. Similar here in Croatia.
I only write this to give those living in US Australia and western europe a betteridea of the situation of members from Central and eastern European countries.
It's such a shame that so many of the pictures he posted have now disappeared.
what i did to my irwin clamps Take the blue plastic handles apart Than drive the pin out which is at the end of the clamp Slide the bar out Hold the 2 pieces that are on the clamp rod Hold them Let them come off Turn them around and assenble the clamp I did this and that fixed the clamps
