Hey all,
I recently picked up a 1/2 inch wide x 1 inch height, top bearing flush trim bit. I want to use this to rout out a 1/2 x 1 inch channel in a cedar 4x4. The problem is my table router causes the bit to stick out approximately a 1/2 inch from the bottom of the table. Ideally I would like to make 4, 1/4th inch passes to get to the final depth of 1 inch, but I don't believe I will be able to do this based on how my table is set up. Can anyone confirm if it would be okay to make a 1/2 cut as the first cut? My concern with the 1/2 inch cut is that it will be difficult to control, but also that it could put premature strain on the bit.
Any advice would be appreciated.
