Tendons & ligaments are body parts critical to movement and strength.
Tenons are wooden "rectangular dowels", of which there are a couple of types: (1) loose (a.k.a. "floating" as BJ mentioned above) tenons and (2) integral tenons. For a single loose tenon connection there are 3- pieces of wood (typically). For an integral tenon joint there are 2- pieces of wood, which can be thought of as male and female parts. There are advantages to either methodology - usually it is maker's preference.
Personally, I use a router to make mortises and I use a table saw to make tenons. If I am making integral tenons - I use a tenoning jig - which is a purpose-built table saw sled. If I am making loose tenons - I use the table saw for tenon width and thickness and I use a miter saw to cut the length (cut the length last). Tenons should be slightly shorter than the mortise depth. In a majority of cases, it is easier to make the mortise first - followed by the tenon being made. If you are mortise cutting the end grain of wood, be very careful as that is the hardest surface of a board to penetrate with your router bit. BE SAFE!
