Bench Rail Clamps
12K views 43 replies 18 participants last post by  Stick486
When I built my Fold Down Router Table, I considered adding T-tracks to the main table top sort of like Mike's (MT Stringer) assembly table. But in the end I decided that I play with too many small screws and parts that might get caught in the tracks and it would be a bad idea for my needs.
However, there are times when it would be very handy to have a way to hold things while sanding or routing or assembling without having to clamp things at the edges of the table. My solution is what I'm calling Bench Rail Clamps because I don't know what else to call them. The idea could be adapted to most any bench or table top.
They are essentially just wooden T-tracks that clamp to the bench with a hook on one end and a toggle clamp on the other that locks under the table and holds the track in place. Stops or other clamps can then be held by the T-track.
I made mine out of some 7/8" hardwood ripped to 1 1/2" wide x 40" long. The track was made on both the table saw and router. I cut a 1/4" wide groove down the the middle with the a box joint blade on the table saw and then ran it through the router with a 1/4" nut slot bit. The router bit didn't have to work quite as hard by cutting the groove first.
The support blocks for the hook and toggle clamp were made out of the 7/8" stock plus 3/4" ply to give me a little extra thickness to clear the 1 1/2" thickness of the table top. They work well and they are long enough to give me about 37" of clamping space if needed. I may add a little non-slip material to the hook end to prevent any chance of slipping but it hasn't been necessary so far.
Great solution, Oliver. Can you give a little more detail on the edge lock, or a photo of that end.
Bill
Here you are, Bill. I used 1 1/2" aluminum angle for the actual hook. The hook is screwed to the spacer / support block which, in turn, is attached to the rail with glue and screws.
...does this stuff come to you while you're sleeping...? Can you send me whatever it is you take...?
I think it's about time to make an "Oliver" folder on my hard drive...right next to "Stick Stuff"...
Nicely done...sure does solve those middle-of-the-table clamping needs...and keeps the work off the surface.
Thanks...keep taking that stuff...
Reactions: old55 and vindaloo
+1. Very smart and handy! congrats.
Sid.
@Gaffboat...
I'm positive you know this but for those that don't...
STRUCTURAL ANGLE...
ARCHITECTURAL ANGLE...
#22 ·
Question: When I like something that someone has posted I can click on the brown circle with the thumb in it on the right side of the post.
There are times I like something and would like to show my like but there is no brown circled thumb in that particular comment.
How do I show my like? I've looked for clues but see none. Can someone tell me?
#26 ·
just to the right of the time posting and before subscriptions..
hit the down arrow...
