Freehand Sign routing
22K views 12 replies 7 participants last post by  George II
Hello all,
I'd like to learn how to make simple freehand routed wooden signs.
I have alot of trouble with the router having its own design, I would like to know what tips and tricks, bits selection, wood selection and any other information is available. No I don't plan to go to flee markets or county fairs to make signs, I would just like to be accurate enough to make a sign when asked by a friend. I do not charge for my work that way if it turns into crap
(which sometimes happens) I won't be paying anybody back.
Thanks in advance for any help you can provide
Jim
Hi Jim and welcome! I would suggest doing a search on the forum for free hand routing and sign making. You will probably find a lot of answers to your questions that way. But I am sure others will be along to point you in the right direction as well.
Deb
#4 · (Edited)
I have made a number of freehand signs with a router. I made them out of pine boards. I lay out the letters, usually in an old western letter style, and rout everything except the letters; i.e. I leave the letters raised and rout the background. I use a 1/4" straight bit, usually only 1/8" deep, or whatever I think looks best by eye. This small bit is easier to control while following the letter outlines. I can switch to a larger bit to take away larger areas of the background (where I am not following a line, just hogging out wood).
Larry
Here's an example:
Hi Larry,
Great sign for freehand work.
How do you support the router? skis or use spacer plates next to the workpiece?
Larry, Thank you for this info, I've been trying a "V" bit with a very small router and as I said before, having alot of trouble following a line. I will switch to a 1/4" straight bit set shallow and see how it goes. I've been using cedar I'll try redwood as well as pine and see which routs easier. Thank you all for your input. Please keep posting tips and tricks as they are very helpful to me.
Jim
Thanks George.
I don't have templates. I lay the letters out by hand with a straightedge and by eye. I have a very old motheaten book full of different fonts. It is entitled "20th Edition Speedball Textbook for Pen and Brush Lettering". It was published by the Speedball Co. that made pens, brushes, inks, and accessories for lettering and calligraphy. I refer to the book and then do my best to make my letters look like what is in the book.
Larry
Some use a wide base resting on the sign, others use skis. It's all personal preference.
I've used the computer to draw the sign up, print it, then use an engraver to transfer it to the sign wood. That's how I did these.
