I had to make a new table saw insert today for a dado set.
I used double-sided carpet tape to hold the cast insert to the new hardwood insert.
I used my new 1/2" x 1-1/4" CMT flush-trim router bit and it turned out almost perfect.
However, after prying the cast insert off the new insert the adhesive is stuck to the cast. I mean really stuck! (There is a side story about having to unscrew the set screws after finding out they interfered with the router.)
I tried mineral spirits and then lacquer thinner but neither worked.
How do you remove the adhesive? Any tricks of the trade?
